has any one ever rerouted thier battery? if so wat gauge wire would be good,and weres a good ground in the trunk.
rerouting the battery
there's already a couple thread about rerouting batteries...mostly into the trunk...but our trunks are known to have water leak into them...make sure your trunk is sealed from moisture first.
..and i would give you a link..but my lunch break is almost over with...later.
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
Im going to be doing this at some point in the future.
Im going to use 0 gauge wire and ground the battery through the center seatbelt bolts. Also, im going to use a box to contain the battery. Murray's Autoparts and Autozone sell them, but theyre bulky plastic, and I want something a little nicer, so I'm technically still looking for something that suits my needs.
As far as running that thick of a wire cleanly through the car, im planning on running it through were my A/C lines used to go. From there I'm going to run it either up through the B-Pillar, into the headliner, and back down the F-Pillar in the rear into the trunk, depending upon clearance, or it'll just get routed along the edge of the floor beneath the carpeting, then beneath the rear seats and into the trunk.
Originally posted by HondaTuner808Im going to be doing this at some point in the future.
wal-mart has a pretty good battery box
