window trouble going down
    Hi Ive searched but it seems every ones problem is teh going up.. First I have power windows. the driver side has real trouble going down.. I have to physically push it down if I dont the motor starts to click and window wont move. ( seems like its binding agains something) but going up theres no problem atall.
    THanks
    window regulator going bad.. get a new one..
    also, clean the window channels and lubricate.. (there's a special lubricant for it)
      i use wd40 to lubricate the window channels, its a temporary fix,it only last a couple of weeks.
      sold to: bootlegcb7, jhondayaaj
      bought from : b3nsonx , *JDM_CB7*, bmxicansd, konig52r,
      Slick_Nine, CB7_213
        Lubrication goes a long way. And I wouldnt use WD40 to lubricate window channels. It can eat up the rubber around it and if you have tint its a no no. Use lithium grease or this lead stuff for got what it was called.
          cool ok ill give that a try.. what about teflon spray???
            thanks worked like a charme
              also check to see if its rubbing on any of the rubber trim. I did that window pin kit DIY and i accidentally installed the window wrong and it was going up the tract fine up until halfway when it hit the rubber trim
                I have that same problem but I also think that the lower part of the window channel, the rubber strip in the lower part of the door, has fallen off again
                Arcadia Green Crew Member #9
                  Wouldn't be talking about graphite? Kind of a powder type substance for lubrication....
                  Speaking of sigs... aRaKNiD, yours takes up more than my entire screen. Shrink it, or I will.
