paperclip trick
    paperclip trick
    can somebody explain this trick 2 me because my check engine light came on and i cant afford anything but a paperclip. never happened til i tightened the white cap in the FITV. first time i ever saw any cb7 engine light come on.
    passenger kick panel, 2 wires - blue connector. stick the paperclip in, then turn key onto acc and watch the check engine blink.
    miss my turbo cb7
      ok u gotta b a little bit more specific than that... u jus got me confused
        ok i got 3 solid flashes and 3 fast flashes. whatz this mean?
          sounds like 33
          I don't think 33 is a valid code, you might want to check again
            turnz out its 43. but whats fuel supply system susposed 2 tell me... i mean it was runnin fine so i dont think its pump or injectorz
              Is your S key broken?
              It could be a regulator, a relay, your sending unit.... Any number of things. How does it run?
              - Rob -
              92 Auto Sedan - "Rustoration"
              85 Toyota 4Runner
              1977 Kawasaki KZ1000/ZX6/10R Hybrid
              2008 HD 1200N
              2009 HD 883N
                when i pull codes, the check engine light doesnt blink...i wanna say its the ABS light...but its def not the CEL....anywho..
                I wanna say theres a sticky'd thread around here somewhere with CEL codes and how to read them. Ironically, unless you really know how to search it out or what to look into, checking them can only tell what the computer is reading thats broken. Like 203cree said, that one code could be a handful of things. You're best bet, if you cant find specifics is to just take it to Honda or a mech and tell them you pulled a code and see if they cant figure it out from there.
                Originally posted by Jarrett
                  yeah 43 can be a lot of different things, you can try searching things like code 43, or fuel supply, etc. Some people have solved it by changing the O2 sensors, but like I said it can be many things.
