Violent front end shaking
    ok so tonight on my way home from the city my front end decides it wants to start shaking and actually bouncing violently under acceleration only... light or soft it really doesn't matter.
    so i'm thinking it's either my wheel bearing or my drive shaft. my cv boot has a tear in it i noticed when i got home and looked under the car.
    anyone have any ideas?
    first off I would jack up the car, and reef on everything to see if anything is completely whacky, and then try rotating your tires, this will rule out if you have a tire/balance issue there.
      well the tire is brand new and installed only 2 days ago. and from looking at the tire the weights are still on the tire
        well it could have a new tire defect, or the weights moved, or anythng. look im just giving you suggestions, to assume that its not the tires by saying they are brand new,well you could be throwing money at your car.
          oh no i understand your trying to help me out with suggestions please dont take my responce the wrong way. i was just letting you know they were new and to my eye everything was there and fine thats all
            sounds like an axle problem to me.
              what makes me wonder is that this problem started after you got new tires...anyway have a look around and yank on the cvs, if its as bad a vibration as u make it sound,should be easy to spot
                well we can cross out it being the tires as i changed them with a different set and i'm still having the same problem
                  my friends 6th gen. had an axle problem 2. used 2 click everytime he turnd hahahah *CLICK..CLICK...CLICK*
                  DONT SWEAT THE TECHNIQUE
                    have your.... half shafts been replaced yet? yes, possibly axle problems perhapsably.
                    it's either...
                    -tires / wheels
                    -ball joints (upper, lower, steering arms thingies, any shot bushings)
                    -half shafts
                    -lugs nuts loose (oh noes! = new wheel)
                    -mythical creatures in your drivetrain somewhere (gremlins, unicorns, etc... )
                      well for those interested, turns out it was the drive axle. picked one up and had the old one out and new one in, in 3 hrs. not bad for never having done one before.
                      thanks to those that gave suggestions.
