Leaks
    Leaks
    Today i was looking at my car and found out it was leaking from where the transmission and block meet and i wanted to know why it leaks from there.
    Stuff For Sale
    It maybe you "rear main oil seal". Did you dry it up 'coz it seems so in the pics.
      Are you sure thats the actual source of the leak. I didnt think it would be possible to have a leak from there cause the only things in there are the clutch pressure plate and flywheel. None of which have anything thats leakable.
        My guesses are its either the flywheel spitting oil from a leaking rear oil seal, or coming down from the head area.
          You rarely see oil get flung right there though. The flywheel might drag some there when you take off the trans but it shouldntn be coming out of the case from that high. You sure it isnt something higher like your distributor seal or something? But it looks dry as hell in that picture unless thats a picture of someone elses car.
            mine leeks to.
            seems 2 me like its in the same spot... HMMMM
            DONT SWEAT THE TECHNIQUE
              when i drive for a while and just let it sit its starts leaking from right there and i believe its my transmission oil.. Well i will double check and make sure ..
              Stuff For Sale
                What about your slave cylinder maybe it's leaking hydraulic fluid.
