Driver Side Window Sticking on the way down
    My driver side window will go down about 3/4 of the way then it will slow down and stop...but if you roll it up a lil and back down and play with it will work...or if you jus grab it and pull it down a lil it will work...but i've noticed it doesn't do that if its raining...
    maybe it just needs to be greased?(if so...where do i need to grease it and what do i use? wd40?) what do you guys think?
    Owner of 93 SE CB7 Coupe, 92 CB9
    ***PM me if you have a Legend or CD5 lip for sale***
    My CB7 SE Coupe Page
    Mine did the same thing. I removed the door panel and found out 1 of the 2 screws was loose from the window track. I tightened it and its all good. Make sure its aligned right before you tighten it.
      haha my driver side n passenger side does that. but ima do wat junyaccord suggested. thanx
      DONT SWEAT THE TECHNIQUE
        X2, yeah theres lot of problems with the windows, sometimes the seals get in the way
        wat?
          k thanks guys ima try that out tomoro
            A quick fix is to spray silicone lubricant in the tracks as well. I wouldn't do this unless you eventually plan on replacing them though.
