My son has a 90 Accord, we changed engine out a few months back and before we changed the speedometer worked fine after we change engines it quit working, this was a change out and not a swap so everything is cut and dry. One mistake I might have made is after reading the manual it says "do not" remove the power steering lines to the vss but its now after the fact. Is there procedure to use to bleed these lines out or could there be another problem I need to look for ? The vss is plugged in. Aslo we pulled the engine with the tran then we reinstalled the old tran to new engine the vss was left on the tran and never removed.... any clues ?
TIA
Jeff
TIA
Jeff
