Hey Guys got a problem... On last Tuesday I asked a friend where was this oil leak coming from. He said I should change the O-ring in the distributor. SO on Saturday I did without any problems until I started to drive my CB7. When starting out at a stop light or a complete stop I have to press the accel. hard to get it to actually move to the same speed of traffic. Once it starts then if I want to accel. faster I have to press it hard again just to change gears. Can someone help me out?
Acceleration Problem
Sounds like you are out of time. Did you set the ignition timing?Originally posted by jayrob333Hey Guys got a problem... On last Tuesday I asked a friend where was this oil leak coming from. He said I should change the O-ring in the distributor. SO on Saturday I did without any problems until I started to drive my CB7. When starting out at a stop light or a complete stop I have to press the accel. hard to get it to actually move to the same speed of traffic. Once it starts then if I want to accel. faster I have to press it hard again just to change gears. Can someone help me out?
maybe you didnt put the plug wires back in the correct order?
----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
NE GUYS, Buy the last of my accord parts
http://www.sears.com/shc/s/search_10...&gobutton=find
Might be better to just see if a local mechanic will set the timing for $10 or $15, unless you think you'll use the gun enough to justify buying one. Or if a local friend or CB7Tuner can help you out.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
.002 seconds on Google gave me the answer...
You pull the little rubber cap on your transmission housing, put the red wire on the #1 sparkplug wire, ground the black wire, then aim the gun in the hole. It flashes a strobe with your ignition pulse. You can then use the markings on your flywheel to set the timing by adjusting the distributor. There are 3 lines... the larger center line marks 15 degrees, which is standard. The two smaller lines on each side are 13 and 17. They mark the factory limits. As long as you're within those 2 lines, you're safe. You can play with the timing within that range to move your powerband around a bit. Advanced timing (towards 17) will give you a little more top end. Retarded timing will give you some more low end. Timing that is well past those parameters will cause lousy performance at best, and engine damage at worst (extremely advanced timing can cause detonation). It sounds to me that your timing is insanely retarded.
