front suspension
    front suspension
    Hello everyone, question...Im assuming the H22 im installing is heavier than the F. Is this gonna cause any major issues with the front springs, should I go stiffer? I am running Ground control adjustable coliovers, stock shocks( will be changing those!), i was thinking i may have to raise it alittle. what do you guys think?
    get a set of billsteins and im pretty sure you'll be fine.
    5 months old and already a lady killer
    Dust & Blood (my bro's band)
    http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=921 03410
      it really shouldnt be that much hevier, baybe like 40-50 lbs, but I doubt it
        I am running all stock suspension on the accord with the H22 and never noticed a different.
        Click Me
          you might have to do something to the rear but it should be all fine. my friend hasnt done anything yet or had any problems
          Accord SE
          93se
          Members Ride
          Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
          Sold to: sulimed, BurtonRiderT6, tishock
            actually my car has coilovers and lowering springs if you're talkin about me... run the same with it set like 1/2 an inch lower than stock and you will be fine... a friend of mine said he tried with the stock suspension and they blew out so don't do that.
            back to do it again... no flipping of accords this time!!!
            Hit me up with techy questions if i don't have an answer i can get an answer...
              having a H22 in your car is just like having a 12 your old kid riding with you in the front all the time. So i would say yes, but not noticeable.
              Your going to want to be able to take turns with all the added HP, i mean most people drop their car.
              ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
              NE GUYS, Buy the last of my accord parts
                when i swapped mine there was no diff. in ride height so i dont think u have anything to worry about just suggest u get shocks u might wont to raise it a little cause i believe the downpipe hangs a little lower i know i bent mine
                BB6 2001 Prelude SH
                Originally posted by Makaveli2k
                Don't be a sissy. Pull out, spit on the tip like they do in the porno's and get back in there.
                =p
                  Yeah, suspension isn't necessary for the swap. But if you want the power, you'll love the car after a good suspension. Transforms it.
                  As mentioned only a weight gain of like 50ish pounds. Probably less.
                  If you really cared just batt. relocate to trunk, cf hood, and like drop a few more pounds in teh front and well you're almost back to normal. Normal + 60hp.
                  Click for my ride thread.
                    Its not heavier...Its about the same as an F. Why does everyone think this? Its only 80 lbs if not a little more heavier than a D series. Thats not much weight for the suspension anyway unless your shit is blown.
                      move the full size battery to the trunk = save 40 pounds right there.
                      ditch P/s, a/c and brackets = another 40 lbs right there.
                        The H22 block is light as anything. I can lift a bare block with one hand. The head weighs more than an F22A head, and the transmissions are about the same. The weight difference is probably no more than 20lbs, if that.
                        Putting 20lbs in the FRONT of your car is different than having it in the passenger seat... but it won't make that much of a difference. I never noticed any handling differences with my swap, and I was on stock suspension for a year as well.
                          really... haha for some reason i didnt think you did yet... sweet
                          Accord SE
                          93se
                          Members Ride
                            Darn it, you're right. I was thinking about J series vs. H series.
                              If it's about 20lbs heavier, throw on a carbon fiber hood. Problem solved.
                              ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
                              Project Deerslayer
                              UPDATE: DEER - 2, CB7 - 0
                              '93 EX 5-speed coupe
                              Short ram intake
                              Tenrai Himoto catback
                              Smashed front end
