Cruise control
    Cruise control
    Since I bought this car the cruise has never worked. I thought after buying that I'd been thru all the fuses and replaced any that were bad, but recently had a problem with interior lights (fuse blew) and decided to check them all again. Found the cruise control fuse had blown so I'm not sure if I overlooked it before or not. Anyway, I switched it out too and the cruise still doesn't work. I'm not getting a light on the button, and of course, nothing on the dash. Any ideas? I know to most people cruise isn't important, however there's quite a few times I get on the highway and take LONG drives. Such as the 800 mile trek I made a week ago. Times like those, I really wish it was working.
    Speaking of sigs... aRaKNiD, yours takes up more than my entire screen. Shrink it, or I will.
    maybe something is disconnected, pull the switch out and check
    wat?
      Cruise Control
      How's your speedometer? When my speed sensor when out it took out cruise control and my speedometer, might be that...
        i had a similar proplem with my 89 legend when i bought it turned out the po had the speedo cable and forgot to plug in the cruise control in the engine bay. check all the connections inside the dash and in the engine bay.
          I use to have a similar problem my button would come on but it wouldn't engage turns out it was a simple vacuumed line.
          Click Me
            check if the cruise Control box under the steering side of the dash is there and plugged in. Check the vacuum line going from the mannifold to the CC unit. Check if there is an actual cable attached to your gas pedal.
            ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
            NE GUYS, Buy the last of my accord parts
              Thanks for the ideas...as it's too dark now, I'll check these tomorrow and see where that gets me.
              Speedometer works fine, but appreciate the idea...
