Clutch Help
    Clutch Help
    I just did a a6 swap in car.... everything done except clutch isnt workin..i press the clutch down and it doesnt come up at all. Also when you push the clutch the clutch arm doesnt move at all?? Everything is hooked up What the hell?
    yea i did post this in Technical aswell. i dont know if its a rule or not but i figured there might be people in here that could help.
    my bro just had this problem. ill ask him how he fixed it. it has to do with the clutch fluild tho.
    miss my turbo cb7
      bleed it out... and you have to pump that clutch.... A LOT for it to build up pressure.
      Fun with Paint... haha.
      OHIO CB7's
        check the clutch fluid, mines done that a few times
        Driving before toke:
        Driving after toke:
        Promote friendly driving, Toke!
        www.myspace.com/fzzy285
          Exactly if there is no fluid or a lot of air in the system the fork will not move. You have to bleed it as previous people mentioned.
            if i did this and it still doing this what than....
              Do it first then ask questions later.
                the reason i ask is becasue we did bleed it and still has problem
                  You sure your bleeding it properly.
                    ok i have done this 4 times wit engine swaps in cb7s. the way i do it is open the little valve on the front of the trans by the slave clyinder. 8mm wrench. fill the cluth fluid resivior full of fluid. get a buddy the watch the vavle you just opened and pump the clutch. pump it about 10- 100 times (depends on how much fluid is in the line already) and see if fluid is shooting out of the valve BUT MAKE SURE the fluid resivior stays full of fluid. its gonna spit a few times and start shooting out, and the resivour fluid will start droppin very fast. if fluid is squirtin out of the vavle and the fluid is dropping quick with the clutch pedal all the way out close the valve. fill the resiviour up and try the clutch. its a lil mess but works.
                    the rebuild!
                    http://www.cb7tuner.com/vbb/showthre...50#post2073450
                      x2 when i changed my clutch i had to pump at least 20 times before i felt it goin any where, and then when i did feel it come up i still had to press down a few more times
                        ok guys thanks ..ill try again....
                          Did it work?
                            if all that bleeding doesn't work then there is a leak somewhere. those hydrolic hoses hold alot of pressure so is if works for a couple days then keeps goin out the slave cylinder is bad. they aren;t that much like 20 or 30 bucks. mine went out and would hold pressure for an hour. its two 12 or 14mm bolts that hold it on and is very easy to install.
                            the rebuild!
                              im gonna try it today....the car is at the school auto shop..... yea the slave cylinder should be good but if not its cheap and easy...
