i recently got a nos kit (dry) for free i installed and everything is hooked up right i bought the right jets for a 50 shot and colder plugs so i had it dynoed and as soon as he sprayed it started to lean out so he stopped he said a new fuel pump might help so i put in a walboro 255 and tried it again still leaned out so he said the only other thing to do is make it wet does this sound right cause i posted a comment earlier saying u need to have a wet kit and someone corrected me and said dry kits r better for small shots i have an h22a with vafc if that helps
thanks for the info so far but i guess my real question is should i be able to run a 50 shot dry without it leaning out and if so is there some other reason its leaning out cause he even dumped as much fuel as the vafc would allow and it still leaned out and should making it wet fix the problem
