Clutch Pedal Problems..!![Pic]
    Ok..so it started giving me problems when i was going to work..it would get stuck floored and wouldn't be able to shift..but then it would come back up and i could shift..but now it's just floored and i can't shift..is it the clutch itself or what?..and around how much is it gonna run me to fix..??..and excuse my rug being dirty.. ..kinda emberrassing
    clutch master cylinder
      what he said above. It just happen to me
      vouches --> mj1220mj,Trickedaccord92, Maple 50175, Customlowz, 92lx
        I had some what the same problem. it would get stuck halfway down and wouldnt come back up unless i pulled it back up with my toe.
        Filled with brake fluid and problem solved for now.
          CMC or its leaking at the slave cylinder causing that.
            you know the same thing just happened to me. I thought my clutch was going out but i put some brake fluid in the small resiovr and now it works fine. I had to pump the clutch a lot
            Maple50175 - you're annoying =P
            Brandoncb7 - I don't mean to come across like an ass but I see why you irritate Aaron now.
            JoshM - Crotch rocket = chick magnet.
              clutch fluid doesnt dissapear may want to check for a leak!
              member ride thread
              DIVULGE MOTORSPORTS
                true it doesn't disappear, but the level will drop as the clutch wears.
                i think it is your clutch MC as mentioned. i would also change the slave cylinder as well so you don't have to worry about it for another 15 years. later.
                Avoiding dirt at all costs
                  I had the same issues when I first bought the car replaces the clutch master cyllinder and the slave also! Good luck!
                    What did that run you parts wise?
                    Hustle Hard! This is a design of some gear I've been workin on.
                      Slave cylinders are cheap. I'd pick one up at napa. As for the cmc idk what you should do. Maybe napa as well .
                        Slave cylinders are 25 max.
                          Sounds like you have a manual
                          hahaha
                          Dont worry, I think you can put like DOT 4 fluid in there and it will work insanely well
                          I'd be more concerned about your wireing job there, fire is a big risk
                          Should've run it under the carpet
                          Your man for wiring solutions!
                          CB7Man's Coupe H22 Swap
                          CB7Man's Sedan Resurrected From The Dead
                            hahaha
                            dont mix fluids!
                            member ride thread
                            DIVULGE MOTORSPORTS
                              Ok..so it can either be the Slave cylinder or the Master Clutch Cylinder..so where are those located at?..ima try bleeding it first and then ill see..but just in case it dosen't work..where is the Master Clutch Cylinder or the Slave Cylinder at?..
