squeaky noise
    squeaky noise
    the past couple of weeks its been very cold in boston and all of a sudden when I'm taking turns....the car squeaks.....idk if its the weather that's causing all of this or maybe something that is rubbing against something......somebody please help......it pisses me off.......
    My Cm7
    My Cb7 (DD)
    maybe your bushings....whenever it gets cold out, they squeak more
      my passenger seat squeaks,.... f$%^ cold weather.....
        is this bad... ??
        do i have to replace them...??
        does this just happen in the winter...??
        My Cm7
        My Cb7 (DD)
          Control arms maybe. Is it only when you turn or when you hit bumps??
          1993 Accord EX
          2011 Subaru STi
            you can try using spray silicone on your bushings to quiet them up
            make sure they're not overly worn tho or they should be replaced
            Watch out for those cement barriers
              yeah this sometimes happens to me in the winter, when it gets below like 40 degrees outside. But it eventually goes away when the car either warms up, or it gets warmer outside. But first check to see that your bushings are all in good shape.
                yea this past week its been extremely cold.....i guess its due to the weather......but ill check it out tommorow at my stepfathers shop and i'll let u guys no wat it was.......thanks
                My Cm7
                My Cb7 (DD)
                  Could it be you upper control arms
