problem whit wire harness
    Every once in a while,my car has no power,like a battery that is going bad.Everything is hook up right but no power(sometimes a very low surge).
    At first i tought it was a bad starter,but when it has power the car starts.
    So i discover that there is some kind of short around the black cable on the starter.When i move the big wire harness(that the black wire come from)the power come back.Sometimes i can go 2-3 month without any problem and suddenly it act up again.
    Any idea what the problem is?I expect some wire failiure but how do i know for sure and were to look for.Sure dont wanna mess something up.
    Thanks
    corrosion on that wire somewhere. i believe that wire is the starters ground, but im not sure.
    miss my turbo cb7
      any idea anyone?I need help please...
        Correct. That is the starter ground wire. They are relatively open to exposure and thus are likely to corrode. You could probably splice and repair it and see if that helps. Did you try tightening the connection?
        Proud owner of the only JJDM full 2.5" catback exhaust!
          yes i tight everything.The problem is that the ground wire goes up in a big harness and i dont want to mess anything in there.Can i simply by-pass it and ground the starter anywhere else on the body ?
          Thanks for that quick reply
            that wire i believe goes back to the fuse box
            miss my turbo cb7
