i cant get my bottom crank removed . the bolt is stuck. i already have the motor blocked from spinning. it is off the car and it is just the block itself. my question is....will pB blaster help loosen it up??? i cant get it loose with my 1/2" impact gun. or my breaker bar even when i stand on the breaker bar. in the past i had to use 3/4" impact gun but i dont have one. i cant think of anything else that would work other then maybee the PB Blaster
bottom crank pulley
You might have to get the honda/acura crank pulley tool (OTC 4731: http://www.sjdiscounttools.com/otc4731.html ), its so much easier with this tool, you don't even need an impact gun.-Josh
91 Accord LX Sedan 5-speed (daily/project) - JDM H22A swap
91 Ford Ranger XLT Supercab 5-speed 2.3L (broke)
