temp sensor question
    I got spare temp sensors from my old car (saturn SL1 SOHC tbi) and i'm starting to lean that a sensor is bad, Can i use the old sensor from that car, or is it going to be a completley different configuation for the sensor itself, i figured if the pigtail was the same, and the thread was the same, i should be good to go... what u guys think
    90 Accord EX F22a1 Auto R.I.P.
    2011 Mazda 3 Hatch 2.5L GS sport HELLO!
    Temp sensors are not universal. The ECU is configured to operate with a different voltage based on the impedance of the thermal resistor/diode in the sensor itself.
    Don't do it. ETCs and thermal sending units are dirt cheap. Just go to Autozone or order one from Majestic and do it right.
    Besides, if you're problem is the ETC (right below the distributor), you especially want to replace that with an original sensor as it controls more than you think. When my ETC went bad, the car would stall, wouldn't start, ran like shit. It was a terrible experience. Since replacing it, ZERO problems.
    Lexus SC300 1JZ-GTE - garage queen
    1991 Honda Accord Ex - daily beats
      Thats the thing... im not going to dish out 149,99 at the dealer, and my cost price at PR 98,99... thats ludacris... going junkyard shoping tomorrow.
        So i went out to the JY today, got 3 sensors. 2 Long and 1 Stubby... and this doesnt make much sence to me. I pull 2 out of the first car, near both rad hoses. the one on the front of the engine was a short stubby one, and the one on the rear was a longer one. Then i get to the 2nd motor, pulled the one on the fropnt, it was long...? How is it one motor has a short stubby one in front, and the other has a long one.. Which sensor is made to go where?
        Thanks
          Bump... anything guys?
            I was looking around for the information i been looking for since yesterday, and still have not found anything at all... anyone able to spread some light on this...
              Im almost positive that the front one (under the distributor, not the one on the front water neck) is stubby. Why don't you pull yours out and compare?
              -Josh
              91 Accord LX Sedan 5-speed (daily/project) - JDM H22A swap
              91 Ford Ranger XLT Supercab 5-speed 2.3L (broke)
                Cause if i run into the same issue where the sensors are different, im going to rip out my hair lol.... But thanks, i will get on that today.
                  ??? I had to buy a new one...and it was like...$10...dirt cheap.
                  It was not the one up front (which you can see on your sig...Left side...bright teal color...right by upper hose) but the one behind that one right above where the tranny and engine join...guys who replaced my clutch in class bumped it. There is also one near the power steering rack correct?
                  I have mine unplugged (the one that you can see easily in your sig) and I get better gas mileage with it like that...by like 20 miles on one tank. I need to test it to confirm that sensor is the cause of this...might all be in my head...and prolly is
                  ____
                    I just replaced the temp sensor in my wifes car yesterday and it was 25.99 at autozone.
                    My Members Ride Thread
                      hmmm...more than I could remember it being..still...not over $40
                      ____
