so I finished my brakes. all my brakes. I did pads and rotors all the way around the car and replaced my two rear calipers. however, because of the extensive brake work I did, just about ALL of my brake fluid has flushed through the system and ended up in an oil pan on my garage floor.
my question is about bleeding my brakes. I know I need to start from the wheel furthest away from the master cylinder first but I don't know if there is a specific way of bleeding when starting from a clean slate.
should I jack up my rear passenger side tire and open the bleeder BEFORE I start to poor fluid in so is pushes any air out. Or should I keep the bleeder closed fill the system, then move from tire to tire and fill up system as I need to. Any feedback would be great guys, thanks a lot.
