who make the best suspension on the market today? need something to handle drag / circuit racing.....what would you recommed
who makes the best suspension?
There are a shit load of options everyone has different preferences. The only thing I can say is do your research. IMO teins are too soft. I have basics on my car I would like a stiffer spring rate if possible.
IMO this looks like the best deal if you have the $..
http://www.cb7tuner.com/vbb/showthread.php?t=76939
Tein makes excellent suspensions"This truck is 100% sh*ts and giggles."
"Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
Disregard females, acquire currency
BUS 62 AIN'T F'ING AROUND!
Originally posted by deevergoteThere is no "best". Figure out what you need, and find the system that meets those needs.
- Soft Original Ride: Stock OEM Suspension
. - Sporty Ride, mild drop, soft, cheap: Sports Springs (Tein H-Tech, Eibach ProKit, Neuspeed Sport) with Mild Dampers (Tokico HP, Bilstein HD)
. - Sporty ride, low ride, firm, expensive: High Rate springs (Eibach Sportline, Neuspeed Race) with High Rate Dampers (Tokico Illuminas, Koni Yellow or Red (non adjustable))
. - Performance Ride, height adjustable, Cheap: Coilovers with non-adjustable Dampers (Tein Basic, Nex GT)
. - Performance Ride, height adjustable, dampening rate adjustable, expensive: Adjustable Coilovers (Tein SS, Tein Comfort, F&F Autolife)
if I had all the money in the world I would get the Tein Cruising Master with the Comfort Sport Dampers controlled with the EDFC
have funDEVOTE
FS: Lokuputha's Stuff
Originally posted by lokuputha[*]Sporty ride, low ride, firm, expensive: High Rate springs (Eibach Sportline, Neuspeed Race) with High Rate Dampers (Tokico Illuminas, Koni Yellow or Red (non adjustable))
So to a lazy person (like me) they are essentially non-adjustable....but if your not lazy (unlike me) you can adjust them all you want....Just be prepared for it to be a few hour ordeal.
Originally posted by King JamesThe reds are adjustable....They just arent adjustable while still on the car
here's a FAQ&A from Koni:
Originally posted by Koni FAQ&A
Q: What is the difference between KONI Special (red) and KONI Sport (yellow)?
A: The KONI Special (red) has been engineered to maximize the ride comfort with good handling performance for each vehicle application. The KONI Sport (yellow) typically starts at a higher initial valving baseline to give a sportier feel and work on vehicles with higher performance parts. In some instances, KONI will only offer a Special or Sport valving and not both. Some modern cars come from the factory with higher tech suspension systems and wheel/tire packages so they would move directly into the Sport range, however they are still valved to give a comfortable ride with very good handling capabilities.DEVOTE
Suspension tuning is most often done by driver feel alone... Lots of trial and error, combined with a working knowledge of the characteristics of the car and the suspension system.
I agree with the benefits of a limited adjustability. Too much to play with in the hands of someone that doesn't know or need all the features, can make a really good suspension system rather crappy. I like my Konis, where I can adjust "stiffness" (rebound only, I believe). My springs are at a set height. More than that, and I'd get myself in trouble... not to mention the constant alignments needed if I were to play with the height!
