Here's my story:
engine's got 278k miles. Ever since I bought it it's been losing oil. I put cardboard under it once, ran it for like 15-20 minutes, and checked the cardboard, and it was clean.
I changed the oil in October, checked the oil yesterday, and my level is below the first hole on the dip stick.
So I added the only quart of oil I owned. Then just for kicks I checked my plugs, which were drenched in oil. The tube portion of the plug wires is not wet with oil however. It's just the lower portion of the plug - the threads and electrode. So I had a spare set of tube seals (not the lower ones...the ones that go on the valve cover), put those in, replaced the wires and plugs.
I read this thread:
http://www.cb7tuner.com/vbb/showthre...lug+tube+seals
Really informative, and a better alternative to replacing your rings. I am hoping my rings are not going/gone, and I don't think they are. The only knowledge I have of piston rings and how to test if they are going bad is:
1.) if you take your oil cap off while running and if it's smoking
2.)if smoke's coming out of your tail pipe
that's all I know.
I took off the cap while it was running, and no smoke, and my tailpipe does not emit any "bad" smoke as well.
Think just replacing the lower tube seals would call it a day? I don't know where to find these, or what they look like since the pictures are not showing up on that DIY.
I read this thread:
that's all I know.
but i dont remember if they have pics on this specific thing.
