Boy IT's cold OUTSIDE
    So my car starts hard basically, it needs a main fuel relay I've come to the conclusion. But I'm not getting one unless I absolutely need one. My car runs fine and starts every time. But today it didn't start. Well it did start once, and me being who I am I had to turn it off just to see if it would start again. And it didn't. Would the cold weather, like 20 degrees or colder affect the MFR issue. I think it would, but dunno. Thanks.
    It's typically heat, not cold, that affects the main relay. I would look elsewhere first.
      What could cause this problem?
        my four door has the same prob. keep me updated i wanna know wassup wit this issue also!
        ----------------------------------I ♥ My CB7----------------------------------
          do you have a fuel leak?
          I had a fuel leak....upper injector o-ring seals and my car was very hesitant to start.
          just think...air/fuel/spark
          limit these things out and you will find your problem. could be an ignitor or coil or distributor...caps can carbon track and cause hella problems.
          I would think it is a spark issue for you though.
          Check out ESP engine mount kits for your CB7!!!
            check the Voltage on your battery.
            DEVOTE
            FS: Lokuputha's Stuff
              As someone has already said, MFR issues are typically hot weather related. When you say it doesn't want to start, does it turn over normally and not crank or does little to nothing happen when you turn the key?
              1992 Accord EX 4dr 5spd - SOLD after just over a decade of ownership
              2000 Subaru Legacy GT wagon 5spd
              AHM Platinum Parts Counterperson
                The ignitor or main relay is most likely the issue. I had this happen to me 2 yrs ago, at 155K. But i live in AZ so that could have sped up the aging process a bit. But your problems are most likely related to those two things.
                  Your vehicle will be hard to start in the cold normally anyway. If you're already having issues with a faulty MFR, the cold won't aggravate that, but the combination of the two will make the vehicle very difficult to start. Think about it: hard starting condition + hard starting condition = really friggin' hard starting condition!
                  ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
                  Project Deerslayer
                  UPDATE: DEER - 2, CB7 - 0
                  '93 EX 5-speed coupe
                  Short ram intake
                  Tenrai Himoto catback
                  Smashed front end
