I did look both under the hood, and inside the car. However, I could not locate it. So where is it? Or do cb7 even have one? If not, what fuse do I need to pull out in order for me to do a compression test on my 93 SE accord?
EFI fuse location so I can do the compressiton test
So the engine doesn't try to start, you can pull the spark plug wires, but it may try to diesel, so you pull the ecu fuse to prevent the injectors from operating....
ever done a compression test?
Obviously not if he said that. Taking out the plugs you get a whirr lol you hear nothing. I did that with mine. But still you want to disable the spark if your doing that unless you want to risk getting shocked by the ignition system which isnt the funnest thing in the world.Originally posted by accordaffairSo the engine doesn't try to start, you can pull the spark plug wires, but it may try to diesel, so you pull the ecu fuse to prevent the injectors from operating....
i usually disconnect something on the distributor to kill the spark, disconnect the resistor box to kill the fuel, then pull all the spark plugs.
