This one has me completely confused. Today I go to make a turn right by my house, so I use my turn signal, everything is still okay at this point. Then after my signal goes off, the little dining sound did not, it actually sped up. My turn signals are not staying on, neither are the lights on the dash, only the dinging sound. Then after like 15 minutes of it it stopped, but then I went to use my turn signals again and it started back up. So far my only two solutions are turn my music up loud enough to drown it out or don't use my turn signals lol. I'm at school right now so I have not had the time to start looking at it, but even if I did I wouldn't know where to look. Like I said this one really has me stumped. Thanks in advanced for your help.
Weird Turn Signal Problem
yeah first thing i would check is the fuse its self, im not to familiar with the blinkers on our cars but it could be the flaser the actual relay that makes the bulbs flash in a sertan sequence. it could also be a short in a wire somewhere. just take your time and look everything over. the fuse and flashers as you may know are damn cheap so id just go ahead and replace the flasher and see if it helps.good luck in your futur tuningHey yo uhhhhhh fry man!!!!
I had that problem last summer and I ended up replacing relays, fuses and the problem still did not go away. Turned out that there was a short in the turn signal stalk and it burned up in the steering column, started smoking and melted down onto my carpet. I replaced the stalk and haven't had a problem since."I'm a dude playing a dude, disguised as another dude"
"That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved."
Romans 10:9
><((((º>
Okay something I forgot to mention, sorry about that, it only does it when it's cold. I think this because like it did it for a solid 15-20 minutes this morning and then for about a minute after using the turnsignals after it quit, and then when I left school today it did it like maybe 10 seconds right after I made my first turn but it hasn't done it since then.Originally posted by 92dmI was actually just being a smart ass, and not really contributing to this at all.
Bought from: cb95spd
