Hey guys, I have a problem, when I turn the key to where to the first position to where the lights turn on in the instrument panel and the car chimes like 5 times if you don't have your seat belt on, both the P and the D4 are luminated on the shift lever indicator, but this is only for a moment, the D4 turns off when the chimming stops and a couple of the other warning/indicator lights turn off. I wanted to know if this was actually a problem; if it's an electrical/transmmision problem; or is it something 92 accords do because my 91 CB7 doesn't? TIA.
When key is first turned
After a couple of seconds
; which if it is gas might explain why the exhaust fumes smell alot like burt excess gasoline every morning. TIA. And your car is sweet DarkShadow
