Head Swap?
    Head Swap?
    Ok folks so if i went with a head swap.. what would be the one for me and what does it go for? thanks for all the help
    some people are against headswaps due to the level of maintenance required to keep them healthy but id say the popular headswaps are jdm f22b and the h23
    either should run you a few hundred dollars but most engine companies dont sell headswaps. your best bet is to check the classifieds on here and wait for an h23 head and IM to pop up and then PM the person about it
    goodluck
    OHIO CB7'S #11
    SOLD
    Members Ride DevlTuning
      ive heard bad things about the head swaps, but im sure if you do it right you wont have any problems
      im pissin on the game feel like i got a weak blatter
        something to think about then.. thanks
          along with those bad things are good things. I'm doing the head swap (h23a head) and as long as you fill in a blind hole with honda bond, it's all smooth sailing. There is a cluster fuck of parts needed between a p14 (h23a) lower crank gear, an f23 head gasket (to meet the bore of the 85mm f22 and the 87mm h23 in the middle - the f23's bore is 86), and an h23 timing belt (some people prefer a 95 gsr for a more snug fitment). Also with the h23a head swap, you can reuse your f22ax exhaust manifold...same port size, same bolt pattern. You don't have to get the complete h23 IM though. I'll be running an f22a6 (cuz it has the butterflies), so I can keep my stock tb (for now ). But the f22a6 runners bolt right up to the head, once again, same port size, same bolt pattern.
          Here's the true DIY written on it. I suggest you read every post twice on this thread, then go to hondoogle.com (courtesy of accord r33) and search "h23 head swap" and read every single post you can find.
          here's the link to the DIY here-
          http://www.cb7tuner.com/vbb/showthread.php?t=16224
          ^^click it or ticket^^
            i have a h23 head for sale if interested please email me at accord4thgen_h22@yahoo.com
            Honda Drive it like you stole it!!
