Whats up. Im doing the usual pull out on handle, down on lock button combo and it for some reason isnt working anymore. I have to do this 3 or 4 times for the door to lock.. Im guessing I need a new lock motor if there is such a thing. Help?
Door wont lock
You got to pull up on the handle then it will lock, if this isn't working anymore something probably came apart inside the door.Originally posted by Crusty CrayonI got the same problem on my driver side door. All the others lock, but the driver side wont push down. I haven't tryed that handle trick. When the doors shut, and I am resting my arm on the door, It will lock after a few seconds, but not much good when you are in the car and cant get out.wat?
