help NEW to accords
    help NEW to accords
    I have a 90 accord ex with the f22a4 motor ....
    When i crank it ..the idle starts off really low then it builds up.. it will pulse up/down/up/down ect
    Then begin to smoke out of the exhaust ...
    I changed the intake manifold and gaskets because the old one was leaking anti freeze
    could i have the vac system set up wrong?
    anybody have a under hood diagram ? i can find one
    Thanks yall
    it ran fine before but the intakemanifold was cracked and leaking antifreeze so i replaced it and it didnt smoke before
    PLEASE HELP
    i think the idleing problem
    can be dirty IAC Valve thing
    you can just clean it
    heres' the link
    http://www.cb7tuner.com/vbb/showthread.php?t=30229
    might now fit the problem but check it out !
    it's easy
    Ride: 2002 Lexus IS300
      yes i cleaned it ..i think i have some vac lines wrong////
      anybody have a diagram?
        replace the two bolt on valves that are on the front of the IM the IACV and the other one sorry dont know the exact names of them but i replaced them and it fixed the problem your having for me
        Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
        But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
          the bolts?
          that ataches the idel air control valve to the intake?
          there just bolts right ?
            what color smoke is it coming out of the tail pipe? if it is excessive white smoke, it sounds to me like you need a head gasket. This would explain your leaking anti-freeze and white smoke billowing out of the ass end of your cb7. Also, as mentioned before, to fix your idle problem I would start by cleaning your IAC valve located on the plenum of your intake manifold. if the problem persists, turn to vacumm lines. you may either have a cracked and coroded line or a missing line. but to check for cracks and corosion, spend around two bucks and pick up a can of carb cleaner. then spray over each vaccum line checking for cracks. you can tell it's cracked by the idle raising (motor revving) with each squirt of the can on that same line.
              The head gasket is good ...the only reason the intakemanifold was leaking was under the egr valve the nipple for a coolant line was broken
              is there i diffrence between a auto and 5 speed manifold?
              Does anybody have a diagram of the vac system ?
              thanks yall
                take the plate off the fitv and tighten down the big white screw inside that. it should fix the problem.
                  also the only difference intake wise is that the throttlebody has a second pulley thing on an automatic
                    ? sorry but what is fitv ?
                    thanks
                      do a search for "erratic surge" and 1 of the threads will have a pic. look man im not gonna sit here and preach to you about searching be4 you ask but in all reality... i do make it easier for you.
                        thanks ...But what i am looking for now is a vacume diagram
                        I searched but cant find on worth a crap
                        anybody have one >?
                          thanks
                          Fast Idle Thermo Valve.... its right beside the idle air control valve. there are two screws on the top take them off and youll see a rubber plunger like thing you saw in the EGR. check for cracks, then theres a white(or milky yellow) cap turn it clockwise until tight. if its cracked replace it. if that doesnt work then follow the steps for reseting the (IACV) id imagine since you unpluged and removed it along with a new IM you may need to "reset" it. someone else posted the thread i think.
                          *Try to avoid adjusting the idle screw unless its moved, loose, or you forgot to put it in on the new manifold.(if i still had access to ALL DATA id pull out the diagram...sorry) however i think if you look itll be posted somewhere!
                          good luck
                            just realized.....
                            go to advance auto or autozone and pick up a Haynes manual... full diagrams for like 15$ i think youll need one anyways, theyre very useful!
                              lol i have been to 3 autozones and 2 pepboys in my area they were out
                              lol
                              I am just rushing because its my wifes car she is drive'n
                              my turbo ef <---thats a no no lol
