wondering about the IAB
    so i got the iab wired to the ecu and im going to run the vacuum hose from the iab to the number 12 location on the h22a intake manifold. does that sound like a good thing to do? or is the iab just going to be controlled by the ecu and its pointless to hookup the vacuum line? is it ok to leave that #12 nipple on the intake manifold not hooked to anything or capped off?
    The IAB is vacuum operated so you need it hooked up to your manifold
    ^^click it or ticket^^
      If you got your IAB wired up in the ECU for stock-like function, you need to hook up the IAB diaphragm port to the IAB solenoid to work properly. Hooking it up to the intake manifold bypasses all this and you just wasted your time having the ECU wired.
        ah ok.. so where on a accord lx do you hook up the iab vacuum hose to if the accords dont have a iab solenoid?
          Did you get the black vacuum tank? Cause that's where the tube from the IAB plate goes, and then a hose from that tank goes to a port on the manifold. I'm guessing you did, cause that is where the wire from the PT6 ecu has to go.
          1992 Prelude S w/swapped H22A
            is the black vacuum tank the round diaphram thing that has the bent nipple on it?
              No, it is a small black tank that should be hanging on the bottom side of the IM. The wires you add should go to that tank...
              The vacuum line should come from that diaphragm around the back on the IM to this tank, and another line should go from the tank into a port on the manifold.
                http://www.cb7tuner.com/vbb/showthre...&highlight=iab
                here's a link of what it looks like, just in case you are talking about the same thing.
                  link isint working
                    sorry I didn't realize you didn't have 30 posts.
                    Here's a DIY on how to fix it, I know you don't have to fix it,but it's some nice pics of it.
                      If you don't know what the IAB solenoid is and you have an LX Accord (F22a1 engine, which would not come with IAB stock), then you must not have bought the entire system.
                      Go to the DIY section and look it up. I know I saw one person selling two IAB solenoids/vacuum tanks in the classifieds section.
                      Anyhow, you need further understanding of the setup, to know what you need and to make it work properly.
                        hey thanks.. that helps alot.
                        ya, your right. i think i got it now though.
