Im not new to this swap ive done it in a couple civics, but i have a 92 accord lx auto, i want to convert, i have a 92 prelude si (h23) 5spd car, will all the 5spd stuff go in my accrod out of the prelude if not what would i need from a 5spd accord i know a h23 tranny will work correct me if im wrong, and i already have a accord 5spd ecu, also the meatal tranny mount that is welded to the frame dose it have to be changed i know a civic one dose when you do a auto to 5spd, and if it dose will the prelude 5spd one work? any healp would be apperciated thanks
5spd swap question
Yes you have to change the tranny bracket in the engine bay and you have the drill and tape the h23 tranny for the accord mount. Some people say you can use the prelude mount and you auto accord bracket but if I would do it I would do it right. But I do't know about being able to use the prelude pedal assembly.-1991 Honda Accord LX H22a-
The ESP mount kit is the easiest way to do the swap (Explicit Speed Performance is an authorized vendor on this site... they make great stuff).
The shifter cables will work. The shifter assembly will work. I don't know for sure about the pedals, but I would think they would work. The slave cylinder will definitely work... not positive on the master cylinder. If the cluster matters, you'll need to find an Accord cluster (obviously...
) You'll also need to get manual Accord axles, as the Prelude ones don't fit, and the auto ones won't work (well, I think the driver's side one MIGHT work... don't quote me on that though).
