Speedo/S light malfunction
    I have a 1991 Accord LX (auto), and the speedometer stopped working and the S light continues to blink while driving. I read Accordztech's technical write-up and found out that it is most likely a faulty speed sensor/pulsar. I know I should check my TCU/ECU codes to make sure, (i'll most like do that later on today or thursday ), but my question is if it is a defective speed sensor, is it something that HAS to be fixed right away to continue driving the car, or can i keep driving the car without doing any mechanical/electrical damage to my CB7?, Thank you in advance for all help;(This site is awesome man )
    you can drive it all you want, but your mileage will be affected as the car is in "limp home" mode. I drove for a couple of months with a bad VSS no major problems to be had, but you should fix it as soon as you can.
      I drove my car for a few days until I got mine fixed. The stupid blinking 's' drove me crazy, lol. The car didn't act any differently, though, so you should be fine.
        Yea I noticed that the odometer is not working either....now my car is that much younger ...lol, thanks for all the input guys , I'm going to try to fix it by the end of this week.
          replace your speed sensor . the top portion of it at least. if you need help, pm me or or my homie, blackcb7. I would say cb7extreme too, but he's in virginia now.
            yeah, your vehicle speed sensor died. most usually its the electrical sensor part of it, the ones you see all over ebay.
              what is this blinking s light i have had a 93 lx sedan and a 93 ex coupe neither had this s light unless it hasn't poped up i will look at my car to see if i just haven't noticed it
              ''COUPE''
              ''WAGON''
                Is it an automatic or a manual? If they are manual, then its not going to have one. If they are automatic, the 's' light will be below the temp gauge, if I remember correctly.
                  my sedan is an auto the coupe is a manual i will go look at it later
                  ''COUPE''
                  ''WAGON''
                    Yup! VSS, when you check for it, it should throw a code 17
                    My Black "H"
                    AL Meet!?
                    //Secret G2I Lover, Shhhhhhh! //
                      The "S" (sport light) is only on the 90-91 automatic model, it helps the car accelarate quicker supposedly..., in the 92-93 model they have the D4 that blinks if there is a problem with the transmission. Thank you jhondayaaj for offering to help me , I've talked to blackCB7 about helping me do a wire tuck, I'll probably pass by his shop or that area some day soon, you guys are awesome and have awesomes rides.. .
                        be careful buying a VSS of of ebay...i got a bunk one
                        1991 EX Coupe
                          i had the same exact problem.
                          just goto a junkyard with a 10mm socket with an extension and look directly below your throttle body, on top of your tranny for this:
                          dont unscrew those bolts that can be removed with a screw driver, only the hex
                          the speed sensor that is held down by 2/3 screws and pull out, and pocket that thing!
                          grab a couple to be safe.
                          I went and got one last year and it's been working flawless ever since, but i still get the S light, i just put a sticker over it :P
