vehicle speed sensor
    i replace my vss and the gear shaft 2 years ago....now my speedometer is acting up again....another thing that i noticed is that the vss harness is coated with gunk from when i had a bad distributor assembly O ring....my questions are....
    1.) could it go bad after only 2 years?
    2.) is the oil gunk around the harness causing resistance to the circuit that could cause the vss to act up?
    3.) if my vss is bad will i have to replace the gear shaft too or i could just replace the top part of it?
    THANKS
    1. Yes
    2. Maybe depends but rarely
    3. No there is a sensor that mounts on top of that shaft that you just replace held on by 2 10mm bolts. You can buy the part off ebay and install yourself.
