Brakes lights dont work...
    hey guys... my brake lights dont work... i've checked the wiring at the rear but im getting no voltage when i step on the brakes.... when i turn the lights on the brake lights go on but when i put my foot on the pedal that extra brightness doesnt come up.... anyone have any ideas.....
    Tommy Gun.... Gunning It all dA waY...
    it's probably the brake light switch, located under the dash on the brake pedal. later.
    Avoiding dirt at all costs
      In addition to the switch, be sure to check your fuses. But it's probably the switch.
      If you have a multi meter, you could just measure the resistance across the pins. One way, you will have infinite resistance, the other, no/little resistance. I'm not sure which way is which on Accords, so you'll just have to try it.
      1992 Prelude S w/swapped H22A
        This same thing happened to me, it was a fuse that was placed in the wrong spot. check your fuses and the switch.
        Originally posted by slammed4thgen
        be risky, be smart, and most of all be creative!
