k so i changed, valve cover gaskets and the head gasket and put a 2 1/2 cat back exhaust and still using the stock down pipe and cat...
now i ran the car today just idleing, and it died... then proceeded to re-start it wouldn't start gave it a break for about 20 mins went out and tapped on the starter with a screw driver, now the starter is working i know that... the car would not fire up... tried it again by tapping the ignition key to the starter and the starter would not stop trying to start even after i have removed the key so i disconnected the battery and thats where im at now.
..well how does it indicate that it's on? Clicking? Engine Turn? It may be the Ignition issue that has happend to others that i know of on here. Any CEL codes?
