As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Gauge Cluster.. PLEASE HELP!!!
    i have a 92 Cb7 with ABS and on my gauge cluster the fuel, temp, rpm, and the odometer are not working b u t the speedometer is working. i have no idea what this could be but i checked all the wires and fuses i believe! and it is all good, if you know what it is that would be great. otherwise can i use a gauge cluster that is NON ABS for my car will it hook up, ( i know i will not have an ABS warning light anymore)
    just get a new one their cheap too!
    Freedom Is Not Free
    U.S Army 02/08 Medically Discharged
      yep just hit up a pick and pull....shouldn't be more then 20 bucks.......just make sure it's the same as whats in your car .......cuz there is two types of them.one is a ns..not sure what the other one is ..just look right below your speedometer and you should see it
      Only Hard Thing is Keeping it Clean
      my ride
