well this is the problem with my car well i just changed the head on my f22a1 (auto) and got everything back in place made sure the timing is on point i checked it 5 times and i filled up all the fluids and charged up the battery then im gettin ready to start the car turns over fine then put the wheels back on the car and then try to move it out of my garage and then the car just bog and then dies then i put it back in park car starts right up then i try to pull it out agian then its dies the car moved about a foot and it died then i try to start it turns over for 5 to 10 seconds then the rpm meter just starts jumping and then its stay low like 300-500 rpm then dies i was tryin to hit the gas pedal but that made it die so im not sure what the problem is but hopefully someone here can help me out
(F22a1) car wont stay on or move
So it runs fine in Park/Neutral?? If so it seems like theres something out of adjustment/wrong with the transmission causing it to stall out. Maybe something is going on with the ignition. I dont know a thing about this but I figured I would throw my thoughts out there.
90 Accord LX Auto
Engine-F22A1
Mods- Intake, Full exhaust, Strut bar, lowering springs.
Future Plans- Paint
check and see if there are any codes stored in the computer, sounds like a tps problem, ive seen it happen like that on preludes before,if u have a chilton they will tell u how to adjust the sensor,other then that double check everything u didLost Motion Inc. Repair and Performance Automotive
Sounds to me like it might be ignition timing. You had to swap the distributors, right? You might look into getting a timing light and checking.
And I know you said timing, but you didn't specify mechanical or ignition, so if you already checked ignition, then ignore me.
Otherwise, I'd check vacuum lines, and check grounds as well. An intermittent ground could cause problems like that.1992 Prelude S w/swapped H22A
