Ok I want to know what intells a bad tranny. Cause I have my stockie and at time I smell a fart smell I think its coming from the tranny idk. What r some signs of different tranny problems
what r the signs of a bad tranny (auto)
mine shifted REALLY hard into second like 3 months before it gave out finally. You could literally feel like a solid metal thud every time. it wasn't fun
Originally posted by charlie0882004Ok I want to know what intells a bad tranny. Cause I have my stockie and at time I smell a fart smell I think its coming from the tranny idk. What r some signs of different tranny problems90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
On my past 90 lx, My D4 lamp would blink on the cluster and another obvious thing was I would have to put it in neutral and then reverse multiple times before it would engage which was really annoying! I live in a court and for 3days had to circle my court multiple times to try to park on the side in one try (very hard with narrow spots and other cars around) I felt like I was a aircraft waiting for ground clearance!"Thizz Bizz R' Uz"
Hear my pussy ROAR!
V-TAK
Variable Transistor Accumulator Kinetosizor
Another way to now your tranny is giving out (or gears are giving out) is when it shifts it will kind of "gradually" go into gear. Kind of like when you don't let the clutch out all the way when driving a manual. (mine does this now when it shifts into 3rd & 4th )3 CB's gone....
1 WK Overland....
Still miss the CB though......maybe one day.
1. Fluid is brown-black and smells burnt
2. Obvious noises - wining - grinding
3. Delayed shifting - SlippingTake that freek show to the park, maybe the squirrels will care.
yea my tranny seems to delay shifting in 3 gear. it take 4 ever for it to hit 4 gear. idk if thats ok or not? i think maybe accord trannys have a slow 3rd gear ratio? idk我愛我的本田
i was driving my brothers cb and the shift was delayed and right before that you could feel vibrations through the pedal then it would shift. i eventually stopped driving it because i didn't want it to crap out while i was driving and went back to my car... it was also hard to shift the auto from gear to gear (park-nuetral-d4)
yea mines doing that for 1 to 2. i have to push the gas and let off the gas at the perfect RPM to get it to shift. *kind of like a manual car with no clutch* if i held the gas were it was the rpm will go up and extra 1k RPM and shift roughly. No metal grinding but def 18 years of wear and tear.
I Have a question SO I CAN GET THIS REPAIRED
automatics have clutches as well right? if i replace the clutch you think that will give my tranny more life and I can get the feeling back shifting 1 to 2? What are the guts of a transmission? What part is it thats going bad on the inside? or do people normally replace a whole tranny?
Originally posted by 604_SEi was driving my brothers cb and the shift was delayed and right before that you could feel vibrations through the pedal then it would shift. i eventually stopped driving it because i didn't want it to crap out while i was driving and went back to my car... it was also hard to shift the auto from gear to gear (park-nuetral-d4)
These are both symptoms of low/bad fluid or worse case a failing torque converter.
"Take that freek show to the park, maybe the squirrels will care.
Originally posted by js593If it smells like rotten eggs, it would sound like a cat converter that needs to be replaced... a burning oil smell is usually tranny/motor.
OH! So that's what it is! It seems like anytime I'm following an old car it smells like rotten eggs. I never thought it'd be the cat.
Originally posted by HyphyAccordMy D4 lamp would blink on the cluster and another obvious thing was I would have to put it in neutral and then reverse multiple times before it would engage which was really annoying!
Anyone know why the light would blink and waht this could be
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
