So i just completed my H22 swap recently, and i have this problem. After i start my car its at 2000 rpm then slowly goes down as it warms up, once it hit about 1.5k it will bog down/stall for just a sec drop to 1k and then catch itself and go back up to 1.5k. Sometimes if i rev it up as it's coming down it will do the stall but catch itself again. If i keep the accelerator depressed it will sounds fine its just when i let off of it. I still don't have my downpipe/ o2 sensor in yet so theres no backpressure at all, i was hoping you guys would just affirm thats the reason or help me figure out what it is actually. I'm rather confused as to what it is if it is not the no o2 sensor/backpressure. Please help thanks a bunch -zac
Stalls then saves itself, over and over
That's surging. If you search for it, you will find many posts on fixes for it. It might be your IACV, FIT, coolant might be low/need bleeding, other things.Originally posted by Jdmh2293So i just completed my H22 swap recently, and i have this problem. After i start my car its at 2000 rpm then slowly goes down as it warms up, once it hit about 1.5k it will bog down/stall for just a sec drop to 1k and then catch itself and go back up to 1.5k. Sometimes if i rev it up as it's coming down it will do the stall but catch itself again. If i keep the accelerator depressed it will sounds fine its just when i let off of it. I still don't have my downpipe/ o2 sensor in yet so theres no backpressure at all, i was hoping you guys would just affirm thats the reason or help me figure out what it is actually. I'm rather confused as to what it is if it is not the no o2 sensor/backpressure. Please help thanks a bunch -zac1992 Prelude S w/swapped H22A
