No Spark Problem F22
    Hey guys I bought a 92 EX yesterday that has no spark. I changed the igniter in the distributor checked that all connections are plugged in good and still nothing. Could it be as simple as the coil is bad? or is there something more involved that it could be?
    1992 Accord EX Sedan F22 Auto
    2007 Chevy Cobalt LS 2.2 Auto
    new spark plugs?
    could be other things.
      There is no spark from the coil.
        Check the cap and button.. and also make sure your plugs are in the right firing order, that's seriously important
        Originally posted by Juice21
        thnx pimpette, your car inspired me to go lower
        Originally posted by GameChewer
        Shiit i heard that, you heard the queen!
          All the wires are in the correct order and it has a brand new cap and rotor along with a new igniter there is just no spark coming off of the coil. I guess I should have explained it a little better.
            Double check coil.... I would a say swap out with a good coil... As check Main a Fuse for the Motor...
              Yeah, check all your fuses, and your coil. When you turn the key from off to run (right before start) do you hear the fuel pump come on? you should be able to. If you don't, then you might be looking at a bad Main Relay.
              If you search, there is a thread on checking the coil.
              1992 Prelude S w/swapped H22A
                problem found!!
                  Thanks for all the info.... Just out of curiousity could a bad computer also be the problem if I switch out the coil and get no where.
