As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Cruise Control---HELP!
    On Wednesday, after a very stressful morning I got in my car to drive back to school (about 100 miles) and got on the highway got it up to about 75mph and went to put the cruise control on. However, once I got it up to speed the button next to the column had a green light and when I set it there cruise control light on the dash came on. When I let my foot off the gas it dropped back down into the 30s. Does anyone know what could be causing this? It eventually ended up working but I want to get it looked at before I sell it. Please help!
    Belize Blue 2008 Honda Accord EX-L Driver
    3.5L V6 and 6 Speed Manual Transmission
    vacuum leak on the CC unit, check all the hoses and make sure they are all connected and not kinked/torn
      Yeah it happens over time. an easy fix. btw, the cruise control unit is on the right side of your engine bay (when facing it). It's towards the front of the car with a long cable comign from it to the firewall. It's kind of circular-ish
      ^^click it or ticket^^
        As an addition to that, it's about the size of a softball, mostly black plastic. It's right next to where the windshield washer fluid tube is.
        Also, check the plug that goes into it. I know after my swap one of the wires that goes into the plug slipped back out of the plug, so the light would come on and stuff but wouldn't work. I had to go through all my vacuum hoses about 4 times before I noticed it.
        1992 Prelude S w/swapped H22A
          there you are.
          courtesy of c91blx7
            My cruise works on and off, depending how cold it is outside ><
            90 Accord EX F22a1 Auto R.I.P.
            2011 Mazda 3 Hatch 2.5L GS sport HELLO!
              there you are.
              courtesy of c91blx7
              wow thanks use my shitty pics haha.
              Yeah check the thing for vaccume and see if the connector slipped off and also see if a fuse is blown or something
              wat?
                haha just searched member's rides for engine pics with a good showing of the cruise control. And yours was the best i could find in 8 minutes lol.
                But shouldn't she rule out a blown fuse since her problem is intermittent? If it was blown then it would never work
                  Yeah, if the fuse was out then I don't think the light would come on. It's probably a vacuum leak somewhere. The way I check is just unplug both ends, put my finger over one end and suck into the other. if it doesn't hold, I've found the problem. There is also a check valve right next to the CC vacuum tank, which, when you unplug it, should suck in air.
                  PittCB7grl: Did you do anything to your car recently? Or is this just out of the blue?
                    Ha did i do anything to my car?!?!? Uh filled it with gas lol. Nah I dont do anything with it just the minimum...I dont know much about cars but I do for one know how to check the fuse and I know what part you are talking about. I will check it out when I get time off work this week. So check the fuse then the vacuum? It just happened on wednesdsay and I used it monday night coming home...I have never noticed it before? Thanks for the help!
                      I still think you won't find anything with the fuses, because the CC light turns on in the dash. I'd say it is vacuum.
                      Good luck.
                        Been to cold to check anything. I will try to get around to it next weekend when madspleen85 comes down...Thanks for your help. Ill let you all know what I find out! Later!
                          yeah my cruise doesnt work when its bellow about 15 or so...... i just dont use the cruise when its that cold.
                          92ex CB7<-SOLD 93ex CB9shiftingshift73C10
                            I didn't see anything missing or wrong with it. I just hope everything that we worked on with your CB this weekend holds up. Hopefully wherever you took it for an oil change last time were just too dumb to check the coolant and not a radiator leak. Just keep an eye out for any puddles under the car in the morning. Probably wouldn't hurt to check the coolant level again after you drive it more. Later
