Thermostat Problem
    Thermostat Problem
    Hey Guys,
    I need some insight.
    I just drove 800 miles straight today and noticed my thermostat/temp guage had a problem.
    The needle stayed at the bottom and sometimes it would go up just above the C and drop down (freeway driving)
    When I would get to a stop light and when I sat with my foot on the brake in drive it would go to the normal 1/4 way up like usual so I suspect its not overheating just something is fishy.
    Anyone experienced this before and can anyone link me to a how to replace it on a cb7 w/ a swapped h22a?
    I have to drive the 400 miles home in the morning so do you think its safe to drive until I can get home to fix it?
    I'll be driving in 15-30 degree temps the whole way from Chicago to MN.
    it should be okay, you would just consume a little more fuel than normal since it isnt operating at the normal temps. id do a little experiement and disconnect the radiator fans.
      ya need a new thermostat
      GOT BOOST???
      massive part out on accord almost everything is going
      http://www.cb7tuner.com/vbb/showthread.php?t=125294
        sounds like you need a new one
          I had the same issue, replaced it and it worked fine.
          90 Accord EX F22a1 Auto R.I.P.
          2011 Mazda 3 Hatch 2.5L GS sport HELLO!
