My 93 has issues. i get horrible fuel mileage, my car is a snail compared to a stock 93 and i cant get it to rev higher than 5000rpm. well it will spike at like 5500 and then drop slowly. anyone have ideas?
Performance isues!
A few people have had this problem lately. One solution was to replace the igniter in the distributor. It's an easy process (I always have a few on hand, just in case... easily pocketable at a junkyard!)
Another is to make sure your ignition timing isn't way off. Also easy to do if you have access to a timing light.
Your valve timing may be off a good deal as well. Have you done the timing belt recently? It may not be set properly, or improper tension could've caused it to skip.
Is your check engine light on? The ECU will often go into "limp mode" if that's on.
Finally, make sure your spark plugs aren't covered in oil.
well just because you cleaned them off and still no power doesn't mean that the oil is still in the sparkplug hole. There has to be an 02 sensor. If its a dx or lx its on top of the exhaust manifold but since you can't see it it has to be an ex and the ex 02 sensors are located right in front of the cat convertor.Originally posted by CB7Novawell it cant be. when i clean them it still has no power. there is no o2 sensor on my car. i mean no hole. no wires. nothing. so what do i do?
to reiterate what Deevs said, replace your valve cover gasket set, this will include four rubber O Rings. Also, if the going gets rough with your oil problem, replace the lower O rings, by following this DIY:
http://www.cb7tuner.com/vbb/showthre...lug+tube+seals (no pics, sorry
I know this won't fix your problem you originally asked about, but it will prevent you from eventually having a cylinder misfire, or in an extremely worse case scenario, burning up all your oil and seizing your engine.
^^click it or ticket^^
