Cruise control not working 95 Accord V6
    On my moms accord v6, 1995 2.7L. the cruise control is not working. The indicator lights work and everything. When I press the button on the steering wheel, the light in the gauge cluster lights up to show its turned on BUT the car will not hold at any speed?
    what do you call 2 lebs in an accord?
    Organized Crime
    check throttle body cable connection
    Cruise works with a metal cable (rubber wrap) to the TB to hold the TB
      Whos Control
      Yup, check the cable at the throttle body.
      Make sure the Speedometer is working, without it the Cruise Control Unit will not work.
      Make sure you have vaccum at the actuator assembly.
      Make sure you have good connections throughout the entire system: Actuator, Switch, Steering Wheel, and Control Unit.
      1997 Honda Accord EX-V6:
      Originally posted by James Matteu
      You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
