i was wondering if neone culd help me i recently blew the motor in my 93 accord so i decided to buy a f22b1. i went and bought an obd2 instead of obd1 so now i am stuck with this swap for about 4 months now with no progress i am ready o fire it up soon but i have some wiring issues. FIrst im looking for a pinout for the ecu for a 96 or 97 accord which i believe to b a POH or POJ, which of course i cant find... I was also wondering if it wuld b bad to run the motor without hooking up the tdc sensor near the timing belt cover... i am using my obd1 dizzy n there is a way to wire it in but i havent found the write up for it i guess..... if anyone can help id be very very thankful
obd2 f22b1
I'm no expert in swapping or changing OBD-II to OBD-I, but I think since you have the VTEC F22B1 you will need to use the ECU from the 1994-95 Honda Accord in order to convert to OBD-I and control the VTEC system. You may be able to retain your distributor, but I am not sure.
Leaving the TDC senor disconnected will trigger the CEL for TDC if your F22Ax ECU is designed to look for that at start-up, if so, you may also trigger a random misfire code and have a rough start (you may have to shut off the motor and try again until the ECU gets the spark timing right, I think it has to make a guess when it looses the TDC sensor).1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
