aftermarket steering wheel question
    hi everybody.... im want to get a aftermarket steering wheel with quick release for my 93 cb...now the questions that i have are...if i have airbag how difficult is to intall it?...what are the best brands ?...what size?...what about the ebay brands?....are they really bad?...of course i search but im a little confused and i want a clearly answer...
    I MISS MY CB7
    You can start here
    http://www.cb7tuner.com/vbb/showthread.php?t=118551
    Theres more if you search....
    Take that freek show to the park, maybe the squirrels will care.
      Originally posted by Old School View Post
      You can start here
      yea thanks man...i searched but im confused...
      I MISS MY CB7
        You need
        A hub adapter. This is the part with the correct splines.
        A hub. This bolts to adapter and you bolt the wheel to it.
        The hub can be solid (stayes on adapter) or quick change (pops off adapter)
        Air bag just unscrews and unplugs.
        CB7 will use a "short" hub adapter if you want the original position of the wheel.
        You would need to get for a 94-97 integra or 92-96 civic or 90-93 Accord.All the same.
        Don't know about ebay brands but if these are the $50 buck ones you will get what you pay for.
        A NRG will run $200 or so without a wheel or lock cover. Add $100 for a lock cover.
        And whatever you want to spend on a wheel.
        Original wheel size is about 360mm.
        You can go down to 330mm with out geting stupid small.
          You need
          ok thanks man thats all i need to know...
          I MISS MY CB7
            how about this combo...
            would it fit?..
            http://www.weaksauceparts.com/store/...at=1933&page=1
            I MISS MY CB7
              yep thats what i got but not just any aftermarket steering wheel will hook up to any hub
              my ride thread
              my photoshoot
                how about a momo 350mm?...or what kind did you recommend?..
                I MISS MY CB7
                  heres all the combos on weksos
                  http://www.weaksauceparts.com/store/home.php?cat=1927
                  my favorite wheels are Nardi ,but it is personal preference
                  all i know is the feeling of an aftermarket hub is amazing compared to factory
                  my ride thread
                  my photoshoot
                    yea i saw all the combos but my personal option was this one
                    http://www.weaksauceparts.com/store/...cat=824&page=1 ...will it fit
                    oh also i find this one on ebay
                    http://cgi.ebay.com/ebaymotors/ws/eB...m=110347124461
                    I MISS MY CB7
                      your just going to have to ask weksos if they make a hub for it that will fit your car....... call them up
                      my bro got a cheap steering wheel that looked good for his 240 ill ask him what site it was tomorrow and post you a link
                      my ride thread
                      my photoshoot
                        Oh thanks man that would be great...
                        I MISS MY CB7
                          Your on the right track.
                          If you don't mind the extra cost consider the V 2.5
                          I use mine a security so it is removed often and the 2.5 handy.
                          http://www.weaksauceparts.com/store/...at=1572&page=1
                          I have the solution to the SRS light defeat. Let me know if you need it.
                            You need
                            the "hub" in your terms is known as a quick release everywhere else in the world.
                            Not necessary, and you can run a wheel with just the "hub adapter" alone.
                            Just to clear that up, but everything else sums up putting an aftermarket wheel on our cars.
                            Using a hub adapter puts the aftermarket wheel just about the same distance away from you as stock
                            Normal length hub adapter + quick release = an extra 4" closer to you and looks goofy.
                            short hub adapter + quick release = almost the same distance away from you as stock.
                            Nardi and Personal wheels use DIFFERENT bolt patterns than Momo, and Sparco
                            Nardi wheels have a bolting hole starting at 12 o'clock whereas momo/sparco have bolting holes starting at 10 and 2o'clock. If you have a quick release from NRG you can use both because the have both bolt patterns. If you have a momo hub and want to buy a nardi/personal wheel, you can buy a nardi/personal bolt adapter that will go on your hub, only an extra half inch.
                              thanks...yea let me know the solution that you have
                              yea i like the momo wheels thats why i need the ngr hub and quick release? right?....thanks ikayto thats great info...
                              I MISS MY CB7
