does anyone know if i were to get EVERYTHING to hook up digital climate control from a jdm cb3 would everything plug up or will i have to use acura cl parts? thanks for any info. i just want everything i dont wanna use acura parts.
it a temp sensor that reads the outside temp, it doesnt have to go in the front bumper
the reason why most people use the acura CL parts, its because there's diagrams for it and availability and cost
for the CB, you aint going to find EVERYTHING UNCUT, let alone the diagram
and if you do in the end it will be very expensive
the guy i got the headlights from said he will get everything as he does for civic ones.
about 200 but ill pay that if i can have everything plug and play and oem.
edit: i do find acura cl's all the time so i think i might just get the thing cheap and do everything j/y, i was looking and doesn't look too complicated.
Hes lying out his ass
It will never be plug and play
custom modification will be required to use it on a LHD cb
Not to mention the wiring is the hardest part. No one here knows the wiring diagram for the climate control itself.
There are ALOT of sensors and componets you need
Exterior temperature sensor
Interior temperature sensor ( build into the climate control unit )
sunlight sensor on dash
evaporator temperature sensor
heater core temperature sensor
a variable blower motor resistor that must be custom mounted into the evaporator coil
electronic control of the heater core doors and heater core valve (very hard part)
I've been on the search for the wiring diagram for the climate control for over a year and can't find anything on the subject for it.
its not hard to track down wiring diagrams for CLs or JDM hondas. youll have to just match up each component and make your own wiring harness, since in an OEM installation it is integrated into the dashboard harness. until it becomes more common, i doubt anybody will be making a diagram really... wire colors vary, as do plug types depending on where you sourced the parts.
Originally posted by Tippey764 View PostI have been trying to find jdm wiring diagrams and can't find anything on the accord anywhere.
Yea project would be your man... I've seen the climate control in person and its fully functional.. he said he spent plenty of hours figuring everything out.. He also said he probably wouldn't disclose the details of the wiring.. guess its gonna have to be trial and error for you guys :td:
Yeah but he gets to be the only one with digital climate control. Bit selfish yeah, but its nice to be the only for awhile.Originally posted by Tippey764 View PostThat seems like a big dick move to the community to not give us the wiring diagram.
" No i did all this hard work and you can't have any of it "Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
