I'm looking at adding the hood struts system to my engine compartment,what all do I need and what size strut works best where do I mount the struts ?
Hood strut conversion
A little searching will get you somewhereOriginally posted by schierholz View PostI'm looking at adding the hood struts system to my engine compartment,what all do I need and what size strut works best where do I mount the struts ?
enjoy!
http://www.cb7tuner.com/vbb/showthre...ht=hood+struts
This setup=winOriginally posted by crazymikey View Post92-95 Acura Legend struts are ideal.
All you need is the hood struts from a 92-95 Legend, a drill, and a tap and die set.
Here's mine, it puts the hood up as far as it will go. This is the best upgrade for someone with a lowered Accord. Numerous times have I hit my head on the hood, or had the hood prop in the way.
'93 LX Wagon (On the back burner)
'92 EX Wagon (Traded)
'93 EX Wagon (Current DD)
I keep forgetting I found 4 sets of these things that actually have good pressure. I haven't even installed the set I was going to put on my car.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Would new ones from a generic brand on eBay work? Like theseOriginally posted by Jarrett View PostI keep forgetting I found 4 sets of these things that actually have good pressure. I haven't even installed the set I was going to put on my car.
http://www.ebay.com/itm/Two-USA-Made...#ht_3400wt_922
If the struts hold good pressure then yes they will and you should not run into any problems.Originally posted by ErMMaC View PostDo struts hold the hood just fine ?
ORLY! I tapped mine so that it will screw in, that's probably why it took me so long.Originally posted by crazymikey View PostYou actually don't need a tap & die set. When putting the pivot ball into your hood hinge, just drill a 9/32 hole, and then it will thread in.
