Wat up guys, i'm planning to replace my front bumper with 92's what modifications will be made?
92 JDM bumper to 90 USDM coupe
Originally posted by r. masajo View PostWat up guys, i'm planning to replace my front bumper with 92's what modifications will be made?
The bumper will fit with no modifications however if you are picky with cosmetics, you might want to change out the headlights and grille to the same year 92-93. The 92-93 bumper has a slight lip where it centers with the grille so it will push your 90-91 grille up more flush with the hood line. (It will become apparent what I mean when you put the bumper on. That said if you fix that issue with a 92-93 grille, a set of 92-93 headlights will make the area more flush and cosmetically correct.
Another fix you could do is actually shave that lip down flush to the bumpers original line. That would make the 90-91 grille and headlights fit with no conversion.
(Note None of the above modifications are necessary to get the bumper to bolt on. These are just the two options you have if u want to do a full 92-93 front conversion or mod the 90-91 lamps/grille to fit a 92-93 bumper like oem.
I am the Yakuza CB7!JDM 96spec H22A 178HP 149TQ
"The JDM Fleet"
1993 Accord Sedan - 2.2 JDM H22a1994 Prelude V-Tec1999 CL 3.02000 Prelude2010 Accord Crosstour - 3.5
1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.51994 Mirage S Sedan - 1.5
1991 Isuzu Impulse RS - 1.6 AWD Turbo1993 Asuna - 1.8 "CDM Impulse XS"
1993 Sentra SE-R - 2.0 SR20de1995 200sx SE-R - 2.0 Sr20ve
To add to Warudakumi's post:
The headlights, corner lights and grill on a 92-93 are different than a 90-91. They curve out more, therefore the 90-91 set up will sit "behind" the 92-93 bumper. It isn't that bad though.
Also, you will want to get the 92-93 bumper support if it doesn't come with it. I could not for the life of me get the 92-93 bumper skin to fit on a 90-91 bumper support. I did the bumper swap 3-4 years ago.
Thanks for the info's guys. i saw that lip at the center of the 92 bumper, i'll shave it down to fit my 90 Head and corner lights, i will try to fit also my intersection lights to it. i also do have 92 bumper support. i'll try to do it on this weekend... i'll keep you posted guys... thanks..
