Alright i did a 90-91 trunk swap on my 92 2 door coupe and got red/clear tails but somehow the trunk dont seem to fit right... its like up a lil and the inner tails are like half an inch further up then the outer tail anyone had this issue before>?
Trunk Swap issue
might wanna try loosening those three 10mm bolts holding the latch assembly and push the latch up as high as itll go and retighten... might be enough to pull it down level
actually its the hook on the car itself, not the trunk. their should be 6 point bolts 1 on left and 1 on right. tighten them and it should even out. dun it beforeOriginally posted by cpmikemight wanna try loosening those three 10mm bolts holding the latch assembly and push the latch up as high as itll go and retighten... might be enough to pull it down level
