White gauges install help
    I go a set of white gauges for my 90 ex 4 door auto. Now i got my dash panl thing off (broke it sort of and need a new one anyone out there selling) and now what do i do. I put the gauges over my old ones but i think im supposed to take of the black ones, how do i do that. Lastly it asks me to wire the power of the gauges int oa power source ie headlight tailight power, where do i find that at, waht color is it and all i need is a power and a ground wire. thnx and i hope i was clear enough
    www.myspace.com/sajunglist
    www.bassdrive.com
    You lay the white gauges over the black ones once u pull the needles off, then what u do for the power source ither you go to the fuse box and you will see 3 male prongs at the top of the fuse box,one is constant, ignition, parking lights, u can grab you power source from there, just use a test light to see which is what, or if you want to grab the actuall parking lights wire which runs under the column and the color is red/black wire, and just ground the wire any were to the frame. -damien
      When i putmy on a long time ago, but that was when they were in style i took my needles off and when i turned the car on, they went all wack, so what i had to do was the rpm and mph gauges, i had turn the car on let it run in park, then put the neddles on, cause if not when i turned the car on the rpm gauge would be like at 4,000rpm and i would be going like 50 miles an hour, but i fixed it, i didnt know back then, but know i do. -damien
        uh yeah, I didnt take mine off either, just slipped them over the needles.Really not that hard if you take your time.
          just make sure you go slow over the needles if you bust one its a pain in the ass.
            same here
            -1992 Accord EX H22 234whp 185wtq
            -1993 Accord EX SOLD
            -1995 Accord EX Wagon Daily Driver
            -2012 GMC Canyon V8 4x4
              ya i broke my temp needle o well
