Rear Door Clips???
    Rear Door Clips???
    Ill try to explain this as best i can..
    On the sedans, when you open the rear doors, theres 2 things on the frame, on the inside of the door: the 3-sided latch and that little switch/clip thing that signals that the door is open. If you push it/pull it the dome/courtesy lights come on/off.
    I was told its called a Door Clip, but im not sure. Its basically a switch saying whether or not the door is open or closed.
    Anyway, i need to know what thats called, and if anyone knows where to get one online. I havent looked into any yards, yet, but in the meantime...
    i tried majestic and tasauto and i couldnt find it at either one of them.
    Im not sure if this is considered INT, EXT, Elec or Switches....
    Any help is appreciated.
    Originally posted by Jarrett
    Nothing? Nobody?
    Its not on the door itself, but on the body of the car. If i can find or get a pic, ill post it up....
      not sure what theyre called but you could hit the junkyard and swipe em from other cars.
      the ones from the 3g's had metal bases.
        I almost wanna say this has a metal base as well. not really sure though. Its only held on by one little screw.
        Ill look for pics...
          is it Illust. No. 17,18,19?
          http://www.hondaautomotiveparts.com/...INATION+SWITCH
            The whole thing. 17. Caster, dude you rock!
            Im on that site right now, i just didnt know where to look
            Ill check my local yards and get a price on them first, but if no luck, then ill def pick it up from there.
            Thanx bro.
              Thanx bro.
              your welcome man!
